Bug in representation
Bug in representation - Сообщения
#1 Опубликовано: 21.04.2010 12:20:15
Nexus
Nexus
0 сообщений из 7 понравились пользователям.
First of all thanks for the great software - it help me alot in the engineering work.
Small bug that i noticed in ver 0.88 - nothing serious just wrong visual representation:
If you enter some variable with units, multiply sign disappears. For example:
Uy:=20.38*10^6mm is represented visually like Uy:=20.3810^6mm but its actual value is correct.
If variable is defined without units, everything is ok.
Thanks.
#2 Опубликовано: 21.04.2010 12:31:55
Группа: Super Administrator
Hello.
Thank you. Will fix this.
Regards.
