function call from function
function call from function - bug or feature ? - Сообщения
#1 Опубликовано: 06.10.2016 14:56:16
Igor Skarine
Igor Skarine
Please look at the attached worksheet.
function inv_sn(x,k) works fine in the main body, but fails is called from another function.
inv_sn.sm (4,61 КиБ) скачан 1342 раз(а).
#2 Опубликовано: 06.10.2016 17:28:44
CBG
CBG
You have to first define the function "sn".
To evaluate "tttt" uses the "=" not ": =".
#3 Опубликовано: 06.10.2016 19:24:27
Mike Kaganski
Mike Kaganski
It should be noted that sn() seemingly depends on uni's EFI for Mathcad libraries; also, it's 32-bit only iirc. So, it OP wants others to see what he sees, he should mention the dependencies.
Here's what e.g. I see:
С уважением, Михаил Каганский
#4 Опубликовано: 06.10.2016 23:15:53
... previously answered but let's see it.
