SMath Studio 0.97.5329 (04 Августа 2014)
SMath Studio 0.97.5329 (04 Августа 2014) - Сообщения
#1 Опубликовано: 04.08.2014 13:23:15
Группа: Super Administrator
Доступна новая версия SMath Studio 0.97.5329
Последние изменения
  • Change units for C, F and Re non-linear units added to package;
  • Built-in variable added: lastError;
  • Support for beta releases of extensions implemented;
  • Donation dialog reworked;
  • Worksheet splitter implemented (vertical and horizontal);
  • ViewerFileType plug-in updated to support full version (BETA);
  • Undo/Redo functionality improved to be more stable;
  • Delete and move operations improved for Collapsed Areas;
  • Behavior of combobox for changing font size improved;
  • Unit Package updated (new units added);
  • Insert Unit dialog improved to allow displaying properties as dimensions if defined.
  • Silent mode of the application improved;
  • Monospace font applied to Output window;
  • Key presses handling improved;
  • SS-2: Fixed issues with lost regions under bottom Area part after save to SM/SMZ file;
  • SS-10: Critical simplification issue fixed (happens sometimes on complex math expressions);
  • SS-36: Fixed issue when changes are lost if a link is followed;
  • SS-37: File name update in window title upon jumping to link target;
  • SS-39: Added "Default" item added to Fractions options for MathRegion;
  • SS-40: Approach to handle invisible empty text subscripts corrected;
  • SS-52: Support for sech() and csch() functions added to differentiation engine;
  • SS-54: Description text is always black now;
  • SS-89: Displaying of incorrect error message fixed for expressions with result shown right after definition;
  • SS-126: Fixed inserted snippet layout when collapsed Area Region exists inside Snippet;
  • SS-133: Description text updated for overridden definitions;
  • SS-141: Critical error on Shift+Right Arrow at the end of the TextRegion;
  • SS-143: Freezing of the application fixed on some copy/paste operations;
  • SS-151: Printing: layout fixed when Page Setup is non-standard;
  • SS-156: Fixed zoom in reference books;
  • SS-160: Wrong results with optimization None fixed;
  • SS-171: Collapsed Area related issues are fixed;
  • SS-173: Wrong display of units with subtext if comma is set as decimal separator;
  • Functions palette updated to insert diff() function with two arguments;
  • Long time Plot calculation fixed when equation for Plot contains empty placeholders;
  • Teamwork Session feature disabled (temporarily);
  • Crashing on application start fixed in case of incorrect response from server on check for update operation;
  • Simplification error fixed (incorrect sign of the operand appeared sometimes for complex expressions);
  • Fixed removing of Regions based on RegionHolder when placeholder is empty;
  • Fixed issue when useless brackets appeared between operands;
  • Fixed issues appears on Custom Regions context menu actions usages (evaluation miss and others);
  • Incorrect MDI icon fixed on page creation;
  • Viewer fixed to support empty Title and/or Description of worksheet (using worksheet properties);
  • Fixed issues with Area collapse/expand operations;
  • Stability improved;
  • Language files updated;
  • Refactoring and optimizations.
Системные требования
  • Desktop (Windows):
    Среда: .NET Framework 2.0
  • Desktop (Linux):
    Среда: Mono 2.0 (libmono-winforms-2.0-cil package) и выше
    Поддерживаемые языки интерфейса (37 языка)
  • [ARA] Арабский / Arabic / العربي
  • [BEL] Белорусский / Belarusian / Беларуская
  • [CAT] Каталанский / Catalan / Català
  • [CHS] Китайский Упрощённый / Chinese (Simplified) / 简体中文
  • [CHT] Китайский Традиционный / Chinese (Traditional) / 簡體中文
  • [DAN] Датский / Danish / Dansk
  • [FAS] Персидский / Persian / فارسی
  • [FIN] Финский / Finnish / Suomi
  • [HEB] Иврит / Hebrew / עברית
  • [IND] Индонезийский / Indonesian / Bahasa Indonesia
  • [JPN] Японский / Japanese / 日本語
  • [KOR] Корейский / Korean / 한국어
  • [LAV] Латышский / Latvian / Latviešu
  • [NOR] Норвежский / Norwegian / Norsk
  • [RON] Румынский / Romanian / Română
  • [SCC] Сербский (Латиница) / Serbian (Latin) / Srpski
  • [SLK] Словацкий / Slovak / Slovenčina
  • [SRP] Сербский (Кириллица) / Serbian (Cyrillic) / Српски
  • [SWE] Шведский / Swedish / Svenska
  • [TUR] Турецкий / Turkish / Türkçe
  • [UKR] Украинский / Ukrainian / Українська
Загрузка
Справка
Руководство по использованию SMath Studio (русский язык). Рекомендуется к чтению пользователям, только начинающим работать с программой для выполнения своих расчётов. Спасибо Сергею Аверкину за создание и подготовку документа.
Справка по программе SMath Studio от Gilberto E. Urroz, Ph.D., P.E. (английский язык):
Другие файлы
Иконки программы SMath Studio () всех размеров (16x16, 24x24, 32x32, 48x48, 64x64, 96x96, 128x128, 256x256) в формате изображений PNG.
Davide Carpi 04.08.2014 17:51:00, уни 07.08.2014 00:27:00, Serg 13.08.2014 06:04:00, Carlos 20.08.2014 05:22:00, tca 02.09.2014 02:40:00
#2 Опубликовано: 20.08.2014 05:32:44
19 сообщений из 134 понравились пользователям.
Андрей, добрый день! Давно не заглядывал на сайт, зашел и вот увидел что многое поменялось, вышла новая версия программы, сайт обновился. Видимо, работа идет и это радует. Меня уже не первый год волнует вопрос и хотелось бы услышать ответ, будет ли поддержка работы с таблицами в SMath? По сути, это единственное что тормозит меня в плане применения программы "на полную катушку".
Serg 20.08.2014 07:45:00
#3 Опубликовано: 27.08.2014 01:18:20
Neuropriest
Neuropriest
0 сообщений из 19 понравились пользователям.
Поддержка портированной версии под Win прекращена?
#4 Опубликовано: 28.08.2014 02:47:11
Serg
Serg
7 сообщений из 105 понравились пользователям.
См. сборку многоуважаемого mkraska
Ученье свет!
