Min and Max value
Min and Max value - Сообщения
#1 Опубликовано: 13.07.2010 16:16:47
Edward Ulle
Edward Ulle
21 сообщений из 182 понравились пользователям.
Typically the functions min and max return the minumum or maximum value of a list of operands. For example
x:=max(1.1,2.2,3.3,-5.5) would return 3.3 and like wise for minimum.
The SMath functions min and max return the minimum or maximum value of a matrix.
To accomplish this in SMath requires a lot of if ... else statements.
Can this be implemented in SMath and make the min and max functions mmin and mmax for matrix operations?
Ed
#2 Опубликовано: 14.07.2010 10:01:45
Edward Ulle
Edward Ulle
Or I realized, the function can check to see if the parameter passed is a matrix or vector, then do what it currently does. If its a list of operands, return the min or max of the list of values.
Ed
Daniel Gajardo 26.09.2025 02:20:01
#3 Опубликовано: 14.07.2010 11:37:06
Группа: Super Administrator
Yes, this is optimal way how it should work. I'll try to find a time to improve min(..) and max(..) functions later.
Regards.
