1 страниц (3 вхождений)
Snippet Decriptions - Сообщения
Hi
would like to know how is possible to add descriptions to a created Snippet and how to avoid that comes up the .sm extention when the snippet is included in a page, as shown below
Francesco
Francesco
Hello Francesco,
As I understood, the "snipped" is like any other SMath file, but if you save it in the "snippet" folder you can insert into your existing worksheet via Snippet Manager (as collapsed area or not). Therefore, just make the *.sm file and pay attention on File=>Properties. There are two options "Summary" and "File atributes". What you put in the Summary - Title that will show as a snippet title ( I suppose that you did not put anything there and that is way the snippet description is the same as your file name - with *.sm added). What you put in the File attributes - Snippet shortcut - that name will appear in the Dynamic Assystance (in order to insert in via Dynamic Assistance, if you lke).
I hope this is the answer to your question.
Hi Radovan,
thanks a lot for the quick feedback; yes this answer completely my question.I have till now ignored the existence of this file => Properties attributes that could be useful to address my issue.
Francesco
Francesco
