1 страниц (7 вхождений)
Text subscript/superscript? - Сообщения
Can we add a subscript to text in SMAth Studio?
I am not referring to variables. I know I can type '.' and then add any subscript.
WroteCan we add a subscript to text in SMAth Studio?
You can subtext a text from Writer region.
Greetings,
I found this gem on the internet (https://community.cvent.com/forums/community-home/digestviewer/viewthread?MessageKey=d60af70b-7b4b-4d89-91a2-a2e7edc1eb6a&CommunityKey=693148f0-28e3-495e-a369-16642c2a4f4f&tab=digestviewer); Just copy/paste the subscript of your choice.
You also have the ability to select a different font type/size (e.g., 「Microsoft Uighur」) to produce a subscript effect.
May this be of Good Help;
⚜ Kenny Lemens, P.E. ᵂᴵ
//Consolidated for cut-and-pasting purposes, the Unicode standard defines complete sub- and super-scripts for
//numbers and common mathematical symbols ( ⁰ ¹ ² ³ ⁴ ⁵ ⁶ ⁷ ⁸ ⁹ ⁺ ⁻ ⁼ ⁽ ⁾ ₀ ₁ ₂ ₃ ₄ ₅ ₆ ₇ ₈ ₉ ₊ ₋ ₌ ₍ ₎ ),
//a full superscript Latin lowercase alphabet except q ( ᵃ ᵇ ᶜ ᵈ ᵉ ᶠ ᵍ ʰ ⁱ ʲ ᵏ ˡ ᵐ ⁿ ᵒ ᵖ _ ʳ ˢ ᵗ ᵘ ᵛ ʷ ˣ ʸ ᶻ ),
//a limited uppercase Latin alphabet ( ᴬ ᴮ ᒼ ᴰ ᴱ ᴳ ᴴ ᴵ ᴶ ᴷ ᴸ ᴹ ᴺ ᴼ ᴾ ᴿ ᵀ ᵁ ⱽ ᵂ ),
// a few subscripted lowercase letters ( ₐ ₑ ₕ ᵢ ⱼ ₖ ₗ ₘ ₙ ₒ ₚ ᵣ ₛ ₜ ᵤ ᵥ ₓ ),
//and some Greek letters ( ᵅ ᵝ ᵞ ᵟ ᵋ ᶿ ᶥ ᶲ ᵠ ᵡ ᵦ ᵧ ᵨ ᵩ ᵪ ).
You can insert subscripts and superscripts inside a text region by typing "Alt + =" to insert a math region:
InsertSubscripts&Superscripts.mov (3,87 МиБ) скачан 885 раз(а).
Best wishes,
Oscar
https://skyground21.blogspot.com/2023/07/insert-subscripts-and-superscripts.html
WroteWroteCan we add a subscript to text in SMAth Studio?
Best wishes,
Oscar
Type '.' and then add any subscript, what should be type to add a superscripts?
Best wishes,
Best wishes,
There is no mechanism for text superscripts like the '.' for text subscripts. Thus you have to use special characters as already mentioned here. Of course, if the subscript is to represent a power, then use the power operator '^'. It won't be part of the variable name, however.
Отредактировано 27.06.2025 08:51:06
