1 страниц (7 вхождений)
Rotate matrix Quadrants - Rotate Matrix Quadrants - Сообщения
Wroteeven simpler
Thanks Davide: great 6179 !
Davide Carpi 11.04.2017 06:22:00
The two red regions created "Unknown error".
The algorithmic chain fails.
Mirror_Problem.sm (20,51 КиБ) скачан 1363 раз(а).
Utilities Matrix Rotate Quadrant.sm (59,03 КиБ) скачан 1373 раз(а).
WroteWhy this happens with attached worksheet?
Mirror_Problem.sm (20,51 КиБ) скачан 1387 раз(а).
You found a bug in el(), thank you!
added in BTS [SS-2438]
WroteYou found a bug in el(), thank you!
Hello Davide,
IMHO, the case reported by collab NDTMA is not a bug.
Simply an instance of "shadow in the context" [Mathematica].
Similar broken algorithmic links have been encountered in Mathcad.
We can't play much with the "vector/matrix" codes.
Here is a similar example in the attached.
Cheers, Jean
Fourier 2D ZOOM Demo QUICK.sm (163,14 КиБ) скачан 1427 раз(а).
![2017-04-10 17_06_46-SMath Studio - [Utilities%20Matrix%20Rotate%20Quadrant.sm_].png](/ru-RU/files/Download/b3ULoL/2017-04-10-17_06_46-SMath-Studio---[Utilities%20Matrix%20Rotate%20Quadrant.sm_].png)
