1 страниц (2 вхождений)
Solving Definite Integrals issues with SMath/Maxima - Solving Definite Integrals issues with SMath/Maxima - Сообщения
Hello SMath Forum,
I'm a relatively new user to SMath and am still figuring out most of its functionality and quirks. For the attached worksheet I am working through three energy transfer calculations for human discharge assessments, all calculations involve solving definite integrals over a defined limit. When defining over the time period of (0,0.000001) I am getting answers magnitudes smaller than expected, the answers expected are shown below (last page of document) and the parameters/constants and base formulas used to derive the SMath worksheet are also referenced below:
Capacitive Discharge - Example Calcs.pdf (766,89 КиБ) скачан 978 раз(а).
The SMath working calculation sheet is here, I feel I've exhausted many different options to try and debug any issues with the calculations but I cannot find anymore alternatives:
Capacitive Discharge -TEMPLATE Case - Solve_1 - Copy.sm (48,93 КиБ) скачан 1655 раз(а).
What's also confusing to me, when defining a longer time integral, the answer is changing? Understanding the function after the initial transient period is mostly a steady-state sinuisoidal, I expect the positive/negative peaks to be cancelling out and not contributing to the area under the curve.. Can some please assist with any functionality I have misinterpreted?
I've been advised to adopt a different engineering package like Matlab/Python (although my coding is not the strongest) and I rather enjoy the GUI of SMath - so if I can solve this quirk here I'd be happy.
Appreciate the community's help!
Cheers,
LADS
Cheers,
LADS
Wrote... The SMath working calculation sheet is here, I feel I've exhausted many different options to try and debug any issues with the calculations but I cannot find anymore alternatives. ...
Hi. The attached can help you debug your calculations.
Capacitive Discharge -TEMPLATE Case - Solve_1 - Copy.sm (100,97 КиБ) скачан 1684 раз(а).
Wrote... What's also confusing to me, when defining a longer time integral, the answer is changing? Understanding the function after the initial transient period is mostly a steady-state sinuisoidal, I expect the positive/negative peaks to be cancelling out and not contributing to the area under the curve.. Can some please assist with any functionality I have misinterpreted?
The steady-state solution has no limit for t -> infinity: this means, it oscillates (you can see it here, for example). It has a sup and inf limit of oscillation, then in the range of oscillation the integral can take any value between the integral range of oscillation.
