Plugins crash in Smath Studio 0.99.7679
Plugins crash in Smath Studio 0.99.7679 - Meta TagsEditor and Text RegiosUtilitues plugin crash - Сообщения
#1 Опубликовано: 08.01.2021 23:53:31
CBG
CBG
Hello
The following plugins crash in Smath Studio 0.99.7679
sergio 09.01.2021 06:08:00
#2 Опубликовано: 09.01.2021 10:40:56
netsonicyxf
netsonicyxf
2 сообщений из 79 понравились пользователям.
I have the similar issue:
#3 Опубликовано: 09.01.2021 11:15:51
2 335 сообщений из 4 031 понравились пользователям.
Группа: Super Administrator
I will update these plug-ins soon.
#4 Опубликовано: 09.01.2021 12:03:10
netsonicyxf
netsonicyxf
Is it possible to add a button to temperally disable plugins so they don't get loaded at startup but still can be checked for update?
#5 Опубликовано: 09.01.2021 12:42:03
Currently it is not possible.
#6 Опубликовано: 10.01.2021 20:27:24
mMath Files and Knovel Meta Tags Editor plug-ins fixed.
#7 Опубликовано: 10.01.2021 23:49:28
CBG
CBG
Thank you.
Thank you.
But the Text Region Utilities plugin keeps crashing
#8 Опубликовано: 11.01.2021 07:40:46
netsonicyxf
netsonicyxf
When installing them through plugin manager, both of them shows "plugin installation fails"
#9 Опубликовано: 11.01.2021 10:00:52
Looking at the screens hot you provided it seems that you have plug-ins installed by manual copy of dll files.
You need to delete such plug-ins first and then install then from Extension Manager.
#10 Опубликовано: 11.01.2021 13:46:54
1 442 сообщений из 2 935 понравились пользователям.
Thank you, I'll try to fix it ASAP.
#11 Опубликовано: 13.01.2021 20:17:43
Davide, I've forgot to make some reviewed Fields public, so it was just impossible to fix the plug-in. Now it is done.
Fixed.
Davide Carpi 14.01.2021 04:07:00
#12 Опубликовано: 13.01.2021 20:49:04
Ruben Sidranski
Ruben Sidranski
UNI's EFI plugin is crashing too.
My new portable install has no plugins at the moment
Should I remove it per 0.99.7610 is available
#13 Опубликовано: 13.01.2021 22:01:00
Strange. Just checked EFI plug-in - it loaded correctly in my SMath Studio installation.
#14 Опубликовано: 14.01.2021 04:08:26
Thank you Andrey
#15 Опубликовано: 14.01.2021 12:30:41
Ruben Sidranski
Ruben Sidranski
As you see from the screenshot above, I'm using version 7610 (portable version). I uninstalled the plugin and reinstalled. The install went well and no errors. However, once I restart SMath, the error pops back up.
Could it be a portable version issue?
