Stable: SMath Studio 0.91 (01 February 2012)
Stable: SMath Studio 0.91 (01 February 2012) - Сообщения
#1 Опубликовано: 01.02.2012 16:00:10
2 343 сообщений из 4 044 понравились пользователям.
Группа: Super Administrator
New SMath Studio 0.91 Stable available
Last changes
  • Ability to trace evaluations through the Output Window implemented;
  • Added ability to modify global variables inside the function using Output Parameters;
  • Trailing zeros option added to Math region;
  • Symbolic evaluation now shown in the Math Region as a simple equal sign (same as for numeric evaluation);
  • PayPal donation method added to Donate dialog;
  • Graph animation improved: animation starts as soon as Plot Region evaluation starts;
  • Optimization of the Math Region now also controls mode of the calculations: Numeric, Symbolic or None;
  • Added ability to remove line from line(..) function using Backspace;
  • Added ability to load plugins from setting directory;
  • Tooltips for the MathRegions with errors (those appeared on mouse hover) restored;
  • Ctrl+= inside the text entry of MathRegion will cause inserting of equal sign now;
  • Empty Math Region removing improved;
  • Support for Tooltips added to Plot Region;
  • Red border is now shown for all Regions evaluated with errors;
  • Optimization context menu is now activated only for Math Region;
  • Undo/Redo options removed from the Context Menu;
  • 'rpm and 'radpm units values corrected;
  • 'rph unit added;
  • Gram unit extended with additional English name "'gram";
  • Options dialog updated: tabs priorities changed, width increased to fix word wrapping issues on Mono;
  • Removed ability to select items from Dynamic Assistance list by pressing the Enter key;
  • Invisible status text issue on program start fixed;
  • Fixed issue appears on separately changing of the axes scale for Plot Regions;
  • Fixed error of representation units with subscript into Dynamic Assistance list;
  • Fixed issue appears when pasting number with standard decimal symbol or entry with subscript into the existing Math Region;
  • Fixed critical Plot Region error appears on wrong input data;
  • Fixed issue when it was impossible to move Region by dragging it's bottom border with a mouse;
  • Fixed error appears on plotting graphs based on some programmable functions that contains if statements;
  • Fixed several errors in symbolic library that causes infinite loop or stack overflow exceptions;
  • Fixed critical error appears when trying to change result (right part after the equal sign) of the equation.- Corrected behavior of showing Regions currently in evaluation state (illuminating them by green rectangle);
  • Fixed error displaying when Variable/Function is not defined - in some case program didn't show the name of variable/function;
  • Fixed inconsistent error displaying when no returning value specified by user for procedures on the Worksheet;
  • Fixed error appears as "ENTER" string filled into the Math Region sometimes trying to insert item from Dynamic Assistance list when no items selected;
  • Fixed Multiple Regions selection issue when Ctrl key pressed;
  • Fixed issue appears when clicking on the selected Region when Scrollbar value is more than zero;
  • Fixed local variables visibility errors;
  • Fixed units parsing error for XMCD files plugin if units name of the program set to English;
  • Language files updated;
  • Refactoring.
System requirements
  • Desktop (Windows):
    Framework: .NET Framework 2.0
  • Desktop (Linux):
Interface languages
Desktop и Handheld (34 languages):
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [ITA] Italian / Italiano
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrain / Українська
    Free Download
    Note: No SMath Studio Handheld 0.91 release will be introduced. Please use the latest stable handheld version (0.90).
    Tutorial
    Other files
  • 2 пользователям понравился этот пост
    Oscar Campo 02.02.2012 23:27:00, gurro 02.02.2012 23:49:00
    #2 Опубликовано: 02.02.2012 23:51:58
    Gilberto E. Urroz
    Gilberto E. Urroz
    23 сообщений из 36 понравились пользователям.
    Thanks for the most recent version of SMath Studio, I'm using it to teach my hydraulics class. I did notice, however, that you cannot longer enter Greek characters in text by using the "Cntl+G" keystrokes. The only way to get Greek characters in text is by clicking them off the "Symbols" palette. Could you restore the ability of entering Greek characters using "Cntl+G" in the next version? Thanks!
    #3 Опубликовано: 03.02.2012 08:39:58
    kilele
    kilele
    Thanks for your hard and valuable work
    May I ask if the handheld version is being discontinued ?
    #4 Опубликовано: 03.02.2012 21:49:21
    Oscar Campo
    Oscar Campo
    Greek characters via "Ctrl+G" method works fine for me in this version
    #5 Опубликовано: 04.02.2012 00:11:57
    Is "Ctrl+G" working for you both in Math and Text regions? It doesn't work in the text region for me as well, as Gilberto mentioned.
    #6 Опубликовано: 04.02.2012 00:30:21
    Hello.
    I reproduced it for Text Regions. Thank you. Will fix it soon.
    I hope to create new Handheld version later.
    Radovan Omorjan 04.02.2012 02:43:00, Oscar Campo 06.02.2012 11:23:00
    #7 Опубликовано: 14.02.2012 08:25:22
    noxx
    noxx
    0 сообщений из 7 понравились пользователям.
    Thx.
    But unfortunately not possible to scale pictures
    Insert \ Picture \ From File
    I make the Picture smaller -> Frame cut the picture
    after this i make the picture bigger, information of the picture get lost (white area)
    regard
