Hide the quotes of a string
Hide the quotes of a string - Сообщения
#1 Опубликовано: 02.12.2014 06:34:04
owndante
owndante
1 сообщений из 15 понравились пользователям.
Is it possible to hide the quotes of a string?
Thanks
#2 Опубликовано: 02.12.2014 07:34:36
1 440 сообщений из 2 929 понравились пользователям.
Yes and nope.
If you need a string as variable, you need to use quotes, and you can't hide them.
If you don't need a string you can use an unknown, using as space separator an unicode character like the 'FIGURE SPACE' (U+2007)
Be careful because this trick could break the worksheet readability (so even could make harder to debug/understand the worksheet).
#3 Опубликовано: 02.12.2014 07:47:13
owndante
owndante
Seems like the "THANK" button is not working.
I'm getting an "Error Occurred" message.
Thanks!
#4 Опубликовано: 02.12.2014 07:52:03
You may vote the SS-164 - Thank button issues
Thanks!
You're welcome
