Adding Search filed in function dialogue window.
Adding Search filed in function dialogue window. - Сообщения
#1 Опубликовано: 25.05.2018 08:56:17
Przemyslaw D. GACIA
Przemyslaw D. GACIA
4 сообщений из 11 понравились пользователям.
After installing library of additional functions (most of which are not in specific subcategories but in "all" ) finding them if you are not know exactly what you are looking, start to be an issue.
I suggest to add Search filed in function dialogue window.
Similar to that in Unit dialogue window. That one works perfect...
That would dramatically improve workflow.
#2 Опубликовано: 25.05.2018 21:36:52
You are not very clear about your suggestion. My understanding is like this:
Assume there is a search dialog about functions and the likes,
Click "search", ODEsolve [for example], then here is the list of 17 solvers
... click on "Rkadapt", bingo in the work sheet.
This is OK because they are strictly numerical solvers doing a single thing.
Next, assume you want to "solve, it would only give 'solve(,), solve(4,)
It will do lot of solving. But, solving is too generic about combination
of methods/techniques.
Smath is like any other CAS: a box of jelly beans.
They become productive by association with complementary tools,
which tools are constructed via programming. The best way to get
familiarized with Smath is visiting "Samples" ... a huge repository !
#3 Опубликовано: 26.05.2018 10:42:45
Przemyslaw D. GACIA
Przemyslaw D. GACIA
Thank you for your fast reaction Jean Giraud.
Nevertheless, My suggestion have nothing to do with familiarity.
It's all about practicability.
If you are looking something that is used rarely, you definitely would like to find it quickly instead scrolling all the way to it.
Oscar Campo 27.05.2018 08:46:00
#4 Опубликовано: 26.05.2018 11:08:10
If you are looking something that is used rarely, you definitely ...
... you definitely recover/adapt from some existing Smath document.
Genfit Lorentz Peak Fit.sm (44,39 КиБ) скачан 1235 раз(а).
#5 Опубликовано: 26.05.2018 11:16:40
Przemyslaw D. GACIA
Przemyslaw D. GACIA
Jean Giraud, should I understand that posting a suggestion of possible improvement are not welcome?
You have right, there is a lot ways to go around. And this for sure not a major issue. Barely minor inconvenience.
But if I do not share my observation, an improvement will not see the light of day. Don't you agree that is possible, minor, but possible improvment?
frapuano 26.05.2018 12:33:00
#6 Опубликовано: 26.05.2018 12:36:53
It is
There's another thing that I'd like to add here... I'll ses what I can do
Oscar Campo 27.05.2018 08:51:00, frapuano 27.05.2018 13:50:00
#7 Опубликовано: 26.05.2018 12:54:07
Przemyslaw D. GACIA
Przemyslaw D. GACIA
Cant wait to see how you will develop the concept, Davide.
#8 Опубликовано: 26.05.2018 22:54:56
Jean, should I understand that posting a suggestion of possible improvement are not welcome?
That's not what what I'm saying. Search dialog box, Ok but search for what.
1. Laplace => nothing, all "Maple courtesy"
2. Fourier => nothing built-in Smathh, all Matlab Courtesy "mwXXX"
search 'sin" ... Oh ! thanks for sin(x), sinh(x)
however pretty well grouped under 'Trig, Hyperbolic"
Read top to bottom the f(x) menu and suggests improving the "category".
Agreed: category "statistics" is missing ... all under "Matrices/Vectors".
#9 Опубликовано: 27.05.2018 08:50:42
Oscar Campo
Oscar Campo
It is
Go ahead Davide, definitely this feature is a must have for SMath!!!
Good idea PDG!!!
frapuano 27.05.2018 13:51:00
#10 Опубликовано: 27.05.2018 18:41:27
Something to adjust probably, but...
Oscar Campo 27.05.2018 18:58:00, NDTM Amarasekera 27.05.2018 23:11:00, sergio 28.05.2018 06:26:00, Przemyslaw D. GACIA 28.05.2018 12:01:00
#11 Опубликовано: 28.05.2018 05:07:21
Przemyslaw D. GACIA
Przemyslaw D. GACIA
Davide, I am impressed.
1) That is the fastest reaction over the improvement suggestion I ever witnessed.
2) Your input with Source bar is more then grate idea.
You are awesome!
#12 Опубликовано: 28.05.2018 11:31:50
... have +
#13 Опубликовано: 28.05.2018 11:56:54
Przemyslaw D. GACIA
Przemyslaw D. GACIA
Jean, could you explain how it is related to the context of this thread?
#14 Опубликовано: 28.05.2018 13:00:10
In the search category, why not have the ODE solvers as well.
Almost the all Smath is under "Matrix", nothing ODE
Between you and me: what PDF, CDF ... have to do in Matrix ?
And so little under Statistics !!!
My understanding of your feature is that you wanted a profitable
reply from a search window, is it ?
#15 Опубликовано: 28.05.2018 14:33:45
Przemyslaw D. GACIA
Przemyslaw D. GACIA
Yes Jean. And Davide surpass my idea with his delivery.
Nevertheless, Now I see your point.
It would improve accessibility of those functions.
#16 Опубликовано: 10.10.2018 10:06:17
Przemyslaw D. GACIA
Przemyslaw D. GACIA
It is a pity that this functionality was not included in the latest desktop version of SMath Studio.
#17 Опубликовано: 10.10.2018 12:35:53
Agreed: ODE solvers category would be nice ... Fourier ... General solvers ...
On the other hand, that will take time but unfortunately => living is not 0 $
Of all those courtesy codes, for instance ODE solvers, by collecting in a
category, could it be considered illegal reverse Engineering ?
#18 Опубликовано: 16.11.2018 07:47:27
2 343 сообщений из 4 042 понравились пользователям.
Группа: Super Administrator
It is included now.
Davide Carpi 16.11.2018 09:05:00, Arie 16.11.2018 11:06:00
#19 Опубликовано: 27.11.2018 15:17:35
Ruben Sidranski
Ruben Sidranski
It is included now.
This means that Jean needs to update
