Duplicate selection with Ctrl+D
Duplicate selection with Ctrl+D - make copy of selected data using Ctrl+D key combination - Сообщения
#1 Опубликовано: 19.04.2017 11:52:11
m227
m227
4 сообщений из 29 понравились и 1 не понравились пользователям.
Dear Andrey,
I am happy user of your SMath Studio (and co-author of a script for students composed of Mathcad problems).
Your program is as powerful/useful/compact for me that I even once donated it.
Many programs use Ctrl+D shortcut to copy and paste selected data. I think it would be useful to add it to SMath.
Michał.
#2 Опубликовано: 19.04.2017 12:49:37
Hello Michal,
1. Press left mouse
2. Brush over the math expression for the solid blue.
3. Click right mouse to get the drop down menu
4. 'Copy'
5. 'Paste' where desired.
Those things are Windows functionalities, all live in Smath
Cheers, Jean
#3 Опубликовано: 19.04.2017 19:54:34
How it should works? I know CTRL+D in excel but here there aren't cells to fill. BTW in SMath there is even the CTRL+mouse drag to clone a region or a group of regions.
#4 Опубликовано: 17.05.2017 10:18:12
m227
m227
In many graphic (WYSIWYG) programs (see Inkscape/PowerPoint) it works like this:
  1. copies selected data to internal buffer (usually not bothering system clipboard)
  2. moves cursor somewhere down or to the right - i.e. two lines below
  3. pastes copied data and leaves cursor in the new position.
In PowerPoint copied data are moved to the right and below.
In Inkscape it is put in the same place as source.
In SMath I'd like to put it two lines below.
My goal is to use keyboard to achieve fast replication, not to have to go back to mouse. The perfect behavior is such:
* I enter some expression
* next I press ^a to select it (or I can omit this step)
* next I press ^d and expression is copied two lines below and cursor is on it, so I can edit slightly copy
Michał
#5 Опубликовано: 06.10.2025 15:24:45
Aiden Cooper
Aiden Cooper
I honestly very much dislike this feature now that it has been implemented. With no easy way to disable the feature, it makes the organization and formatting of large numbers of functions difficult to achieve. I simply want to ctrl+click select several functions to then use the vertical alignment tool to have them all aligned, but the ctrl+drag copy feature makes this very difficult to do as it repeatedly deselects the functions I have already selected forcing me to restart this process.
#6 Опубликовано: 07.10.2025 10:49:56
While I understand the issue, just for context, CTRL+D isn't implemented and CTRL+DRAG works the same as 8 years ago.
#7 Опубликовано: 19.03.2026 09:17:24
Norrah_Casper
Norrah_Casper
That’s a really handy shortcut to have, especially when you're building out complex sheets. If you're looking for a quick way to clean up or extract specific formulas and data from your SMath files to use elsewhere, I’ve found that using a simple online text or data extractor can be a real lifesaver. It’s a nice way to double-check your values without having to manually copy everything over.
