Arctg trigonometric function issue
Arctg trigonometric function issue - Сообщения
#1 Опубликовано: 10.04.2021 19:00:44
sando99
sando99
0 сообщений из 12 понравились пользователям.
When trying to find an angle from it's arctg I get a false result:
I read that some years ago there was a problem with the trigonometric functions in the program, but in my understanding, that should be fixed now.
#2 Опубликовано: 10.04.2021 20:03:05
1 124 сообщений из 1 796 понравились пользователям.
Hi. That value is correct. That function is arc cotangent. You are not thinking about atan (arc tangent) ?
#3 Опубликовано: 10.04.2021 20:08:34
sando99
sando99
I totally made a mistake there...thank you!
#4 Опубликовано: 10.04.2021 20:19:47
There is nothing to fix, Smath does not evaluates the Win coded trig.
Smath will only associate units and decimal display.
