Meta Properties
Meta Properties - Is there any way to link the meta properties to the tex box? - Сообщения
#1 Опубликовано: 03.05.2019 07:35:34
Seckin USLU
Seckin USLU
0 сообщений из 9 понравились пользователям.
Hi all
I have just learned to Smath Studio?
I have got a few questions. These will be easy questions, sorry for taking your time.
1- Can i add more meta properties, like checked by , realese date .....
2-Can i link the meta properties to the text file.
3- Is it possible to enter meta properties as a 2 row at page setup menu. I can do it now but one row is not enough for my template.
In a brief, i want to create a templates which includes many meta properties.Then i want to edit footer and header with rev no, checked by company image etc...
I am so glad to know this program.
Seckin
#2 Опубликовано: 03.05.2019 09:43:45
You can have cartouche at will.
Template Cartouche.sm (19,42 КиБ) скачан 1189 раз(а).
#3 Опубликовано: 03.05.2019 10:28:05
Seckin USLU
Seckin USLU
Do i need to open this file without any speacial plugin?
Thanks a lot btw
#4 Опубликовано: 03.05.2019 12:52:58
Just download/open ... it won't ask for billions $
#5 Опубликовано: 04.05.2019 07:17:07
Not with fields, as for now.
You mean picking the values from an external file? In this case, not. Otherwise meta properties are in the File > Properties... tab.
Sure, go in the bottom-right corner of the program window, on the left of the magnifier icon there is a dropdown selector, here you can choose "pages view" mode. In that mode you can double-click header or footer area and arrange items there in the way you want.
#6 Опубликовано: 07.05.2019 17:04:19
Seckin USLU
Seckin USLU
Thanks for your helps
