1 страниц (6 вхождений)
Standard templates? - Is it possible to create (and re-use) a template in smath? - Сообщения
Hi everyone, I’ve been using smath for about a year now (since mathcad became completely rubbish!) and use it for standard engineering calcs (mechanical and structural mainly).
I’m freelance so tend to perform calcs for many clients and have not yet found a way to create a standard calculation sheet template.
For example, whenever I start a new project I’d like a header or something on the front page to display my company name and a few other fields for title, project number, that sort of thing. Possibly even have a margin down one side for referencing standards or notes. Something like the sci calc sheets that are online would be great!
Does anyone know of a way to do this or is there a plug-in somewhere?
Any advice would be much appreciated.
Thanks!
Richard
Thanks!
Richard
you can use:
Insert -> Header and Footer
Insert -> Field
Also you can see this post by Alvaro (Razonar)
https://en.smath.com/forum/yaf_postst13853_Automatic-numbering-sections-book.aspx
Insert -> Field
Few ways of presenting professional works. Any use ?
Template.sm (15,57 КиБ) скачан 1922 раз(а).
Template Background Multiple.sm (14,22 КиБ) скачан 1830 раз(а).
Template Cartouche.sm (19,42 КиБ) скачан 1746 раз(а).
Template Background Construct.sm (47,88 КиБ) скачан 1822 раз(а).
Template Cartouche Venturi.sm (21,78 КиБ) скачан 1694 раз(а).
Template Else Source.sm (3,94 КиБ) скачан 1744 раз(а).
Template Cartouche CREATE.sm (53,17 КиБ) скачан 1673 раз(а).
Template Cartouche Saved.sm (4,53 КиБ) скачан 1640 раз(а).
Template Guy.sm (2,65 КиБ) скачан 1746 раз(а).
Template Cartouche Example.sm (34,49 КиБ) скачан 1665 раз(а).
Template YellowCorn.sm (3,31 КиБ) скачан 1702 раз(а).
Template Cartouche Geoff.sm (31,7 КиБ) скачан 1665 раз(а).
Template Cartouche Otherwise.sm (74,54 КиБ) скачан 1684 раз(а).
Hi, apologies for the delayed response! The templates linked below are great - thank you for providing these.
I've looked at a few and haven't quite found what I need yet but I'll work on it. Once I have something I'll post it here so everyone else can use it (if they want to!)
Thanks again,
Richard
Thanks again,
Richard
WroteI've looked at a few and haven't quite found what I need yet
Visit them all for the next month !
Foot note standard/references best go in collapsed above document.
Create an empty file with your template settings and set it as readonly, when you try to save Smath will ask you a new name.
