number formatting
number formatting - Сообщения
#1 Опубликовано: 07.11.2017 08:36:57
Paulius
Paulius
0 сообщений из 11 понравились пользователям.
Is posssible to change answer number format?
example from 2*10^2 to 200 etc?
P.S. Thank You for Yours reponses it helps very much learning SMath.
#2 Опубликовано: 07.11.2017 11:56:02
Please give more from your source, attach work sheet will help.
Cheers, Jean
#3 Опубликовано: 07.11.2017 11:57:17
did you check "Exponential threshold" ?
#4 Опубликовано: 07.11.2017 17:40:20
Section operation results formatting.sm (25,88 КиБ) скачан 1292 раз(а).
This is page
SMath Studio Documents> Display Control (Results Formatting)
in the interactive handbook (you can find it in the extension manager)
frapuano 08.11.2017 04:24:00
