Absolute Path in include
Absolute Path in include - Сообщения
#1 Опубликовано: 17.11.2024 23:01:38
Ralph-Peter Weiß
Ralph-Peter Weiß
I would like to specify an absolute path in the include() in the form "include( "%My_Path%\test.sm" ). Unfortunately, I get an error message here. The post "yaf_postst17310_include-function-issues.aspx" describes this possibility of using absolute paths.
Is there a solution here?
Regards Ralph
#2 Опубликовано: 17.11.2024 23:13:58
1 539 сообщений из 1 854 понравились пользователям.
Environment variables are inherited from Explorer when the application is launched. If you create such a variable after the program has been launched, it will not be defined. You need to restart the program and follow a simple rule: first define the variable, then launch the program.
