Stable: SMath Studio 0.99.7808 (18 May 2021)
Stable: SMath Studio 0.99.7808 (18 May 2021) - Сообщения
#1 Опубликовано: 17.05.2021 18:30:25
Группа: Super Administrator
Список изменений (между версиями 0.99.7632 и 0.99.7808)
Улучшения
  • Experimental support of new Document mode implemented;
  • Added ability to select Custom Region PlugIn which will be used in Document Mode;
  • Scaling mode is saved between sessions now;
  • The following auto scaling modes added: page width, content width, full page;
  • gf (Gram-force) unit added;
  • Picture Region automatically scale drag'n'droped image according to available page width;
  • Preview in SMath Viewer menu item added to Tools menu;
  • Added support for Regions with custom line breaks;
  • Support for page breaks added for Container Regions;
  • "Break on pages bounds" menu item added to Text Region (option turned on by default for new documents);
  • Support to format content fragments added in Text Region (font size, font family, font weight; font style, text decoration, text color, background color, lines interval, paragraphs in Document mode);
  • Added possibility to restore automatic line breaks mode in Text Region by doubleclick on resizer;
  • Document mode: Support for ordered/unordered lists added;
  • Automatic replacement context menu item added to TextRegion;
  • Search in TextRegion significantly improved;
  • Text Region: Show all characters context menu item added;
  • Account menu item added to UI: allows to log in using smath.com credentials to unlock additional features;
  • Full version of the SMath Viewer is available based on Account status now;
  • Worksheet Author field automatically filled in with a name from Account for new Worksheets/Documents;
  • Ctrl+Enter allowed in TextRegion inside Worksheet now - adds a paragraph to the text;
  • Inserting lists allowed in TextRegion inside Worksheet now;
  • Interface translation to Hindi added;
  • Multiple improvements performed in Search functionality (better support in MathRegion; critical issues fixed; better support for search in Descriptions and Area/Separator; automatic scrolling in Document mode);
  • Cursor movement corrected while the mouse pointer is between the pages in Worksheet mode;
  • About dialog improved: links to author/developer projects provided;
  • Automatic update of the plug-ins on program start after installation of the new SMath Studio version implemented;
  • Search Panel extended with the following options: Case sensitive, Whole word only, Exclude disabled, Exclude invisible;
  • Text Region improved to support pasting Images/Regions from clipboard;
  • Added ability to enable/disable compression of the Viewer output assemblies (may help to reduce false positive detection by AV);
  • Detailed description added in the Account dialog.
Исправления
  • Better support for broken Worksheet files implemented;
  • Hidden exceptions fixed in SMath Viewer applications;
  • Rendering of text improved (the same content looks more similar on screen and on print out);
  • Multi-threading issues fixed in MathRegion and TextRegion;
  • Disable/enable evaluation for Area Region when auto-evaluation disabled fixed;
  • Critical error happened sometimes when using Del keyboard button in Math Region fixed;
  • Issue related to pasting into Regions which contains description fixed;
  • Printing when grid rendering enabled fixed;
  • Critical issue rarely happens on file with specific Region types opening fixed;
  • Fixed critical errors happened sometimes on file open;
  • Blinking tooltips on status bar items hovering fixed;
  • Visible special XML symbols fixed in Text Region;
  • Issues related to work with ordered/unordered lists fixed;
  • Loading of Area Titles and Region Description fixed;
  • Handling of incorrectly used BR tag in TextRegion fixed;
  • Critical error sometimes happened in TextRegion near line break fixed;
  • Better control of Field content implemented for TextRegion;
  • TextRegion functionality improved (history vs Children Regions, stability, performance);
  • Possibility to specify/change text restored in SMath Viewer;
  • Better cursor handling in TextRegion;
  • SS-4635: Symbol "\" is allowed as a special character in Math Region now (related errors fixed);
  • SS-4625: Children Regions locations and translations status when switching program language fixed;
  • SS-4621: Spacing improved while rendering int(2)/int(4) functions;
  • Changes to fix encoded terms text related issues in Math Region and Plot Region (including representation in Viewer);
  • SS-3566: Automatic scrolling to the focused description text corrected;
  • SS-4601: Lost of options on copy/paste of MathRegions fixed;
  • Crash on start in Linux fixed - Account menu removed from version for Linux;
  • Critical issue happens sometimes on text pasting fixed in Text Region;
  • Rendering Font Styles fixed on Linux;
  • SS-4661: Displaying ellipsys for large matrices fixed for results when Optimization set to None;
  • Saving of the Worksheet previously opened without all required plug-ins loaded will not loose a data anymore;
  • SS-4650:Loading plug-ins from the Network location allowed now (this fixes issues happens sometimes after copying plug-ins between computers);
  • Critical error happened sometimes on editing Document fixed;
  • Performance issue experienced with Worksheets/Documents containing Header/Footer fixed;
  • Cursor movement corrected while the mouse pointer is between the pages in Document mode;
  • Scrolling to cursor improved in Worksheet mode;
  • Several text encoding related issues in MathRegion fixed;
  • Worksheet/Document autoscrolling enabled during work with selection inside a Region;
  • Minor improvements performed for scrolling;
  • Switching to Header/Footer by doubleclick fixed for the Worksheets contains Separator Region and background set;
  • Text encoding related issue fixed in Plot Region;
  • Critical issues happens on unexpected DoubleClickTime value provided by system fixed;
  • Generating executables with SMath Viewer fixed;
  • Incorrect cursor position fixed in Math Region for situations where multiplication operator automatically added before unit;
  • Fixed content error happens during copy/paste inside TextRegion when working with content contains Regions;
  • Behavior of save to Viewer dialog corrected.
Разное
  • DEV: Line breaks is supported now for custom Regions (IRegionWithLineBreaks interface);
  • DEV: Added possibility to extend SMath Studio with menu item in File, Edit, Tools or Help drop-down of main menu;
  • Code cleanup;
  • Refactoring;
  • Smart auto replacement functionality implemented for Text Region in Document Mode (f.e. inserting --- finalized by Enter will be replaced with horizontal rule; filling in equation in text will be detected as well);
  • Horizontal/vertical align toolbar buttons made hidden in Document mode;
  • Children Regions rendering improved;
  • Automatic replacement improved for MathRegions;
  • TextRegion: Text selection rendering improved;
  • Changing text formatting now affects on children Regions in the selected range;
  • Document mode: Handling of complex formatting significantly improved;
  • Selection logic improved in TextRegion;
  • Handling of mouse click out of Region bounds improved in Document mode;
  • Interface translations updated;
  • MathRegion moved to a separate plug-in;
  • AreaRegion moved to a separate plug-in;
  • Support for non-standard DPI screens improved;
  • Text Region stability significantly improved;
  • Logic of line height setting improved for Text Region;
  • Mouse cursor mode corrected for Text Region on mouse move with Ctrl/Shift button pressed;
  • Displaying of the progress improved in Splash screen;
  • Program startup speed improved.
Скачать
SMathStudioDesktop.0_99_7808.Mono.tar.gz (1,46 МиБ) скачан 5761 раз(а).
SMathStudioDesktop.0_99_7808.Setup.msi (2,34 МиБ) скачан 20046 раз(а).
System requirements
  • Desktop (Windows):
  • Desktop (Linux):
Interface languages (37 languages)
  • [ARA] Arabic / العربي
  • [BUL] Bulgarian / Български
  • [CAT] Catalan / Català
  • [CZE] Czech / Čeština
  • [DAN] Danish / Dansk
  • [DUT] Dutch / Nederlands
  • [ENG] English / English
  • [FAS] Persian / فارسی
  • [FIN] Finnish / Suomi
  • [FRE] French / Français
  • [GER] German / Deutsch
  • [GRE] Greek / Ελληνικά
  • [HEB] Hebrew / עברית
  • [HUN] Hungarian / Magyar
  • [ITA] Italian / Italiano
  • [JPN] Japanese / 日本語
  • [KOR] Korean / 한국어
  • [LAV] Latvian / Latviešu
  • [LTH] Lithuanian / Lietuvių
  • [NOR] Norwegian / Norsk
  • [POL] Polish / Polski
  • [RON] Romanian / Română
  • [RUS] Russian / Русский
  • [SCR] Croatian / Hrvatski
  • [SLK] Slovak / Slovenčina
  • [SPA] Spanish / Español
  • [SWE] Swedish / Svenska
  • [TUR] Turkish / Türkçe
  • [UKR] Ukrainian / Українська
Tutorial
Other files
churichuro 17.05.2021 20:56:00, NDTM Amarasekera 17.05.2021 23:38:00, bdrunagle 18.05.2021 03:42:00, sergio 18.05.2021 14:08:00, IVR 19.05.2021 06:04:00
#2 Опубликовано: 17.05.2021 18:49:26
SMath Studio in the Cloud updated with Core ver. 0.99.7808.
Hint regarding Account menu: if you want to change your displayed name please follow this link: https://en.smath.com/profile.aspx
Ryan Freund 27.05.2021 15:34:00
#3 Опубликовано: 23.01.2024 12:14:22
stephenhawking
stephenhawking
Hint regarding Account menu: if you want to change your displayed name please follow this link: https://en.smath.com/profile.aspxiq test
Great tool for all engineers.
#4 Опубликовано: 05.03.2024 01:10:35
Jason McCool
Jason McCool
9 сообщений из 78 понравились пользователям.
I made the mistake of installing the newest version and now a bunch of my plugins that I need to use right now won't work with it. But I can't get to any of the old versions that worked. Are old versions like build 7808 no longer accessible?!?!
#5 Опубликовано: 05.03.2024 01:14:08
Jason McCool
Jason McCool
Never mind. I just realized the download link is bad. Once I corrected the link in my browser address bar, I was able to get back to previous version to download.
