Normal/Gaussian Function or Method: Normal Probability Density
Normal/Gaussian Function or Method: Normal Probability Density - Сообщения
#1 Опубликовано: 06.01.2023 19:08:49
Mark R Harris
Mark R Harris
5 сообщений из 90 понравились пользователям.
This matrix generator (thanks gUrrozEN) produces random 'equal-probability' values for a given center value and tolerance band.
I'm hoping to revise this to return values within a normal/Gaussian probability as illustrated:
Random to Normal.sm (42,72 КиБ) скачан 1319 раз(а).
Any thoughts?
#2 Опубликовано: 06.01.2023 22:47:00
Any thoughts ?
Native Smath plugins generate uniform randoms.
The Central Theorem proves that enough uniform randoms
generate a Normal Distribution.
You simply need to bin in an histogram utility.
Is that is what you are looking for ?
Otherwise, I don't understand your request.
Cheers ... Jean.
#3 Опубликовано: 07.01.2023 02:07:39
Mark R Harris
Mark R Harris
Thank you for the reply Jean.
I'm after a method or function that will return a random value with the probability that 68.2% of the time it will be within 1 sigma, and 95.4% of the time it will be within 2 sigmas, etc.
#4 Опубликовано: 07.01.2023 04:13:06
Hi. For 'convert' random uniform distributed numbers between 0 and 1 to another probability distribution, in your case, for get some normal distributed numbers you can use the inverses of the cdf distributions. You can check that here for 1000 numbers you have the desired mean and std deviation
so, I guess that in your function rmat this is the function for normal distributed numbers
random to nomral.sm (5,54 КиБ) скачан 1366 раз(а).
Mark R Harris 07.01.2023 05:25:00
#5 Опубликовано: 07.01.2023 05:32:57
Mark R Harris
Mark R Harris
Thanks Alvaro, very greatly appreciated.
For me, the sample file has a problem:
#6 Опубликовано: 07.01.2023 05:55:38
Hi. I mean: substitute that M[i,j] into your rmat(...) function for get normal distributed numbers with the rmat algorithm instad uniform distributed ones.
Mark R Harris 07.01.2023 06:22:00
#7 Опубликовано: 07.01.2023 11:22:38
I don't understand completely ... sorry.
However, from a native random sigma, you can solve for a desired other one.
Cheers, be good Down Under ... Jean.
Random NORMAL Histogram Copy.sm (44,16 КиБ) скачан 1296 раз(а).
#8 Опубликовано: 07.01.2023 15:44:13
Mark R Harris
Mark R Harris
Thank you both. Alvaro: perfect, thank you.
Here is the working update:
20230109 Random to Normal.sm (54,5 КиБ) скачан 1395 раз(а).
#9 Опубликовано: 09.01.2023 01:41:49
Mark R Harris
Mark R Harris
See the updated post above.
#10 Опубликовано: 09.01.2023 12:44:09
20230109 Random to Normal_1.sm (81,83 КиБ) скачан 1346 раз(а).
