How to expand a matrix?
How to expand a matrix? - Сообщения
#1 Опубликовано: 28.03.2025 22:46:06
netsonicyxf
netsonicyxf
2 сообщений из 79 понравились пользователям.
How to expand a 2*2 matrix to a 3*4 matrix?
#2 Опубликовано: 29.03.2025 02:00:51
1 436 сообщений из 2 918 понравились пользователям.
You can simply define a value for an index out of the existing range, the matrix will be expanded to contain that new element.
example
netsonicyxf 29.03.2025 16:18:00
#3 Опубликовано: 01.04.2025 06:29:20
⚜ Kenny Lemens, P.E. ᵂᴵ
85 сообщений из 179 понравились пользователям.
Greetings,
The easiest way to expand a 2x2 is to select the matrix; you will note a black handle at the bottom-right hand corner; just click'n-drag to the larger 3x4 matrix.
per the help:
If you change your mind about dimensions you can always change the matrix dimensions. Just click inside the matrix on the right lower corner. The black square with a vertical and horizontal line will appear. With the left mouse button (mouse pointer will change the appearance) drag and correct the dimensions. You can do that even if the placeholders are not empty,
Resize Matrix
https://smath.com/wiki/Print.aspx?Page=Matrices
May this be of Good Help;
netsonicyxf 04.04.2025 20:16:00
