Measured values in practical seminar
Measured values in practical seminar - Сообщения
#1 Опубликовано: 09.11.2018 12:33:40
Phili Marx
Phili Marx
Hello people,
I'm new to this kind of software. Normally i work with excel.
I'm doing internships with students where they measuring for example for different flow the losses in a system. In Excel i did that calculation in a table, but it was hard to display the formulars.
So now my problem is: When i put the values which were measured in a matrix, it is not possible to square it...
Addition is workig really well.
So should i put it in lists? But with lists its not possible to do addition...
You may have a look to my data...
i have the vector v1 and in the formula i need v1^2, but it doesnt calculate the right value...
Praktikum Venturi Blende.sm (34,72 КиБ) скачан 1233 раз(а).
Thanks for you reply
#2 Опубликовано: 09.11.2018 13:22:20
Hello people,
Hi. You can use v1[k for square it, or better, not using the k range, with the vectorize operator (the arrow in the matrix palette) when the expression is evaluated for some more complicated expression than sums or products by scalars. Please, see the attached.
Praktikum Venturi Blende.sm (30,88 КиБ) скачан 1224 раз(а).
SMath vectorization is something like dot operator in matlab.
#3 Опубликовано: 09.11.2018 20:14:12
... few more stuff for your Classroom Internships.
The orifice Plate [ISO-5167] is the standard I have use since Windows.
Previous to Windows, used Sharp pocket calculator iterative method.
Previous to calculating machinery: used the Foxboro booklet and log tables.
One way or another, Iso-5167 implements the 1970 Foxboro.
Orifice plate is an Engineering document.
Inst_Colebrook MOODY.sm (19,13 КиБ) скачан 1209 раз(а).
Inst_Orifice Plate.sm (387,98 КиБ) скачан 1287 раз(а).
Inst_Flow Profile.sm (673,87 КиБ) скачан 1330 раз(а).
#4 Опубликовано: 09.11.2018 20:41:42
... a much better demonstrative Vena Contracta.
#5 Опубликовано: 13.11.2018 09:00:58
Phili Marx
Phili Marx
Dear people,
thanks for all of your replys. I didnt think, that i would get a answer.
Helped a lot and I understood the problem.
Thanks also for all the feature documents relating to the orifice/venturi calculation.
Thanks.
#6 Опубликовано: 13.11.2018 10:53:09
1. [1975..77] I was involved with the Montreal sewage pumping station, at the time the world
biggest project of the kind, presented to an International Symposium [Yougoslavia].
17 pumps 100000 UGM each, of which two variable speed, 139 ft deep. At the top discharge, 17 Venturi
flow measuring devices, each 8 ft diameter [Brooks ~ 1000000 $ each] Pump engine 4500 HP each.
2. The best beta ratio [Orifice Plate] is around 0.62. Installed in machined meter run and lab tested
give the best accurate mass-flow rate. An industrial plant may have 100's measuring points. It won't
be be practical to have each flow meter associated with its own calibration. Instead we calculate/bore
each orifice plate with its own beta ratio, thus minimizing the burden of the Instrument Men !
No point to purchase expensive Orifice Plate software, Smath does it just perfect.
