Design Response Spectra - Graphing
Design Response Spectra - Graphing - Сообщения
#1 Опубликовано: 09.05.2023 05:31:47
GFDIntano
GFDIntano
Good day,
So I was shifting from Mathcad to SMath and I can't seem to do this properly. How do I get around graphing this response spectra.I'm quite new to SMath so please be understanding if I don't know of some functions within the program.
Design Response Spectra.sm (27,5 КиБ) скачан 1385 раз(а).
This is hot it works finely in Mathcad, what would be your suggestions?
Thank you for any help,
#2 Опубликовано: 09.05.2023 07:42:11
Here you have your file fixed.
Design Response Spectra_00.sm (28,4 КиБ) скачан 1367 раз(а).
The issues:
The function was made using "while", that is a loop iterator. You have to use if(), or cases() if you prefer (the latter is part of a 3rd party plugin).
The evaluation for multiple values has to be done using vectorize() or alternatively by a loop
The built-in plot variable is always x for static plots, t to add animations.
#3 Опубликовано: 09.05.2023 08:45:17
Doctored in Smath SS 6179.
Cheers ... Jean.
Design Response Spectra Doctored.sm (32,53 КиБ) скачан 1382 раз(а).
#4 Опубликовано: 10.05.2023 08:19:24
... smooth derivative added.
Design Response Spectra Doctored.sm (108,16 КиБ) скачан 1326 раз(а).
#5 Опубликовано: 10.05.2023 14:55:05
An alternative way to write boolean of your function is using ltle() function.
It is one of functions of Custom Functions Plugin.
#6 Опубликовано: 11.05.2023 11:41:33
Thanks for your project. Saved in my personal project files.
I best remember visiting Manilla [April 1987]
Take care in Philippines ... Jean
Project Seismic Manilla.sm (570,28 КиБ) скачан 1386 раз(а).
