SMath Studio 0.98.6325 (26 April 2017)
SMath Studio 0.98.6325 (26 April 2017) - Сообщения
#1 Опубликовано: 26.04.2017 16:03:46
Группа: Super Administrator
Скачать
SMathStudioDesktop.0_98_6325.Mono.tar.gz (1,24 МиБ) скачан 2706 раз(а).
SMathStudioDesktop.0_98_6325.Setup.msi (2,11 МиБ) скачан 5524 раз(а).
10 пользователям понравился этот пост
sergio 26.04.2017 16:42:00, Arie 26.04.2017 16:52:00, Davide Carpi 26.04.2017 19:15:00, frapuano 27.04.2017 01:33:00, Radovan Omorjan 27.04.2017 03:12:00, Mikaël 27.04.2017 06:57:00, IVR 27.04.2017 07:27:00, Вячеслав Мезенцев 27.04.2017 12:03:00, NDTM Amarasekera 28.04.2017 04:19:00, Martin Kraska 29.04.2017 09:04:00
#2 Опубликовано: 28.04.2017 07:34:42
Built-in function Clear(..) implemented to remove variables/units/functions defined above on the Worksheet;
Function Clear(...) previously available in Custom Functions plugin removed from that extension (from this version of SMath Studio onwards)
#3 Опубликовано: 28.04.2017 11:08:31
karlashnikov
karlashnikov
1 сообщений из 2 понравились пользователям.
Due to wrong dpi detection, the user interface is inconsistent, the Contents of the ui Areas are too snall and don't match the actual pointer Location.
The screenshot is made on a win10 13" macbook pro with definitly not 96dpi.
#4 Опубликовано: 28.04.2017 13:00:09
I guess you have to remove image region plugin.
#5 Опубликовано: 28.04.2017 13:21:32
karlashnikov
karlashnikov
Thank you, that's it!
Davide Carpi 28.04.2017 13:34:00
#6 Опубликовано: 29.04.2017 09:23:41
Clear() doesn't work with vectorize(), whereas IsDefined() does.
It is not really essential to have that feature but the response indicates successful execution, which is wrong.
Clear.sm (29,29 КиБ) скачан 1743 раз(а).
IVR 29.04.2017 14:52:00
#7 Опубликовано: 30.04.2017 19:38:29
Hello Martin,
Clear(,)=1 looks a Matlab code that clears the work space
from previous assigned values. Thus, it renders the algorithm
of the "work space" scalar wrt their respective scalar running
iterators x, y ...
In the attached "Fourier Quantum"... x,y are returned scalar
only for the double integrator. The Mathcad double integrator
is coded implicit of 'x,y' scalar ... much simpler but less
educative.
Fourier Quantum CoC Copy.sm (97,81 КиБ) скачан 1776 раз(а).
