Function parameters bug - continued?
Function parameters bug - continued? - Сообщения
#1 Опубликовано: 09.07.1980 12:10:23
Hello Andrey,
I am not sure but I suppose this is connected with the changing in function arguments bug discussed in Functions behave differently in 0.9
Here is an example using integration.
1. This is the calculation at the beginning
2. This is when recalculate (F9)
Here is the sm file recalculate problem
It reported that variable "x" is not defined (actually, it should be that way). Do not understand what happened here?
#2 Опубликовано: 25.01.2012 20:10:06
The previous post had a problem with date (Internal Forum problem). It was not reported in the recent post lists.
