Open SM file problem
Open SM file problem - Issue to open a sm file by the version 0.99 (build: 6955) - Сообщения
#1 Опубликовано: 16.01.2019 03:05:48
Kedziora
Kedziora
The file created and saved in version 0.99 (build 6884) cannot be open in version 0.99 (build: 6955).
The software installed on Windows 10 Enterprise, x64.
SK
#2 Опубликовано: 16.01.2019 12:11:18
Hello Slawek,
Can you share the file? What error message do you get when you try to open the file?
Andrey Ivashov 16.01.2019 13:08:00
#3 Опубликовано: 16.01.2019 16:37:58
Kedziora
Kedziora
Hello Davide,
Here is this file.
Best Regards,
Slawek
test.sm (344,7 КиБ) скачан 1391 раз(а).
#4 Опубликовано: 16.01.2019 17:24:00
Группа: Super Administrator
Here is this file.
Slawek,
This is an issue of the latest nightly builds. Just fixed it so the file can be opened ok now.
Will release a new nightly build in about an hour.
Thank you very much for the report!
Update: Fix is available in this release: https://en.smath.com/forum/yaf_postst17061_Beta--SMath-Studio-0-99-6956--17-January-2019.aspx
Davide Carpi 16.01.2019 20:10:00
