[Maxima Plugin] is a custom Maxima function call-able in SMath
[Maxima Plugin] is a custom Maxima function call-able in SMath - Can SMath call a custom Maxima function? - Сообщения
#1 Опубликовано: 22.05.2018 07:06:49
Adriaan Knox
Adriaan Knox
0 сообщений из 25 понравились пользователям.
I have defined a function in Maxima but am unable to call it in SMath... I've searched around and tried a bunch of different syntaxes buy am still new to this so if it does indeed work I couldn't get it going... Any help would be appreciated.
Attached are the Maxima .mac file and the SMath file attempting to call it.
func_gradient_divergence_curl.7z (329 Б) скачан 705 раз(а).
calling custom Maxima function.sm (4,01 КиБ) скачан 1271 раз(а).
#2 Опубликовано: 22.05.2018 10:04:58
Forget what does not work outside of native Smath
Maths Grad_Div_Curl.sm (12,21 КиБ) скачан 1345 раз(а).
#3 Опубликовано: 22.05.2018 10:50:39
Jacob.sm (53,35 КиБ) скачан 1303 раз(а).
#4 Опубликовано: 22.05.2018 13:32:17
It seems that there is a conflict with the vector package (load(vect) is executed at maxima startup in the plugin). If you remove that call, then your macro is loaded. I only tried this in wxmaxima. See Insert> Maxima> Log> wxm to see what the plugin does at startup.
