1 страниц (4 вхождений)
Unexpected End of File - Cannot open file anymore...! - Cannot open file - Сообщения
Hi Folks,
SMath crashed, and I cannot open my file anymore.
The message I get when attempting to open the file is as follows:
Unexpected end of file whiile parsing Name has occurred. Line 2825, position 60
When SMath crashed, I pressed the save button (maybe not the best idea...)
Any ideas for recovering the file? Thanks.
LorenzPantograph Kinematik Kasten ENTWURF B.sm (506,14 КиБ) скачан 1275 раз(а).
Hello Lorenz,
here it is what can be recovered:
Pantograph%20Kinematik%20Kasten%20ENTWURF%20B_RECOVER.sm (506,09 КиБ) скачан 1460 раз(а).
any idea about the causes/circumstances of the crash?
Lorenz Grimm 12.01.2017 13:28:00
Hi Davide
Everything is recovered! Thank you very much!
I've been confronted from time to time with SMath crashing...but was never a problem since use to save quite frequently.
I have no clue what may has caused the problem....
Lorenz
Lorenz
Lorenz, hello.
I see you are using 0.97.5346. This version of SMath Studio has known bugs related to crashing and broken files, so I would suggest you to upgrade if it is possible.
Best regards, Andrey Ivashov.
Davide Carpi 12.01.2017 14:04:00
