How to get integration value in range
How to get integration value in range - Сообщения
#1 Опубликовано: 30.01.2021 11:19:03
netsonicyxf
netsonicyxf
2 сообщений из 79 понравились пользователям.
Smath
MathCAD Prime
#2 Опубликовано: 30.01.2021 11:41:19
in Smath you have to use explicit vectorization
#3 Опубликовано: 30.01.2021 11:44:56
netsonicyxf
netsonicyxf
Thanks.
BTW: Whern I click "THANK" button. it shows "Error"
#4 Опубликовано: 30.01.2021 16:11:02
BTW: When I click "THANK" button. it shows "Error"
Does not work from dark age.
#5 Опубликовано: 30.01.2021 23:09:00
... hyperfast.
#6 Опубликовано: 31.01.2021 03:09:04
NDTM Amarasekera
NDTM Amarasekera
Integration values extended to matrix and nested arrays.
#7 Опубликовано: 31.01.2021 12:02:40
@ netsonicyxf
In the mean time you cogitate more integration visit Samples
Simpson ranges from exact [I only know two functions] to absolute crap.
In cases considered adequate, it may still be a poor integrator.
... poor integrator on the long range of the integration variate X.
This case is rescued via Romberg-Simpson ... in the attachment.
Other integrations are only possible via Carlos Adaptive ∫Adaptive(f,a,b,N,ε).
These two documents are minimalist visit.
Good idea to first construct the project unit-less.
Chhers ... Jean
Integrate Compendium_20 Simpson-Romberg Adaptive.sm (139,06 КиБ) скачан 1255 раз(а).
Integral 00000000 MASTER ToolBox.sm (477,13 КиБ) скачан 1182 раз(а).
#8 Опубликовано: 03.02.2021 10:03:27
netsonicyxf
netsonicyxf
Thank you friends, you always give very detailed help.
