[SS-3567] File corrupted after using region protection option
[SS-3567] File corrupted after using region protection option - Сообщения
#1 Опубликовано: 03.10.2018 13:07:21
cecile
cecile
0 сообщений из 7 понравились пользователям.
I used protection regions on my smath sheet. Everything went fine until I close the sheet and try to reopen it. I can't expand areas no more (no "+" or "-" available anymore at the begining of the area), nor can I run calculations...
The file seems corrupted. It weights only 20kB...
Someone help please!
File is available here :corrupted file.sm (20,13 КиБ) скачан 1440 раз(а)..
Thanks a lot
#2 Опубликовано: 03.10.2018 14:28:12
Confirmed and reproduced; (also, reproducible using copy and paste on opened worksheets).
Unfortunately everything in the protected area is lost (not saved, hence not recoverable).
Bug reported as SS-3567.
#3 Опубликовано: 04.10.2018 04:24:57
cecile
cecile
Thank you for having a look at it anyway.
#4 Опубликовано: 04.10.2018 07:05:14
Thank you for reporting; as posted in the BTS the issue is fixed now and will be part of the next release.
#5 Опубликовано: 14.07.2022 23:21:58
oscar mauricio
oscar mauricio
1 сообщений из 10 понравились пользователям.
Hi, I find a similar error when I use region protection and secondary areas are contained in the area.
When opening the sheet all content is protected
I hope it could be improved in future versions.
