Inversing Matrix in MES algorithme
Inversing Matrix in MES algorithme - Problem with inversing Matrix - Сообщения
#1 Опубликовано: 27.08.2018 14:20:21
Krystian
Krystian
I have an issue when I try to inverse matrix without defining new variable Smath does a calculation, but when I try to define new variable with value of inversed matrix smath stucks in calculation. I attached a file, hope You can help me
RAMA3.sm (52,97 КиБ) скачан 1363 раз(а).
#2 Опубликовано: 27.08.2018 15:34:15
Fridel Selitsky
Fridel Selitsky
Try the eval () function
#3 Опубликовано: 27.08.2018 16:41:22
By opening your file, errors correspond to two incomplete formulas. If you delete the two missing terms (one for formula) and if you set the rating to "numeric" (in your file The two formulas are set to "symbolic"), everything will work correctly.
[albumimg]1510[/albumimg]
[albumimg]1511[/albumimg]
Sergio
#4 Опубликовано: 27.08.2018 20:27:56
Few things are not defined. Doctored in red, red is numeric.
Observe ... diag(v)
RAMA3.sm (68,17 КиБ) скачан 1356 раз(а).
#5 Опубликовано: 28.08.2018 03:03:20
Krystian
Krystian
Formulas was incomplete because of having problems with calculating equation. Your solutions helped me. Thank You everyone, thread's exhausted
