How to add plugins to Portable SMath Studio
How to add plugins to Portable SMath Studio - datsnl - Сообщения
#1 Опубликовано: 16.05.2013 18:10:16
Dharmit
Dharmit
I am having portable SMath studio and I want to add plugin of importing and exporting from/to .ods file, I have downloaded the plugin, where do I store it so that SMath Portable can find it?
Cheers
Dharmit
#2 Опубликовано: 16.05.2013 18:21:46
1 440 сообщений из 2 929 понравились пользователям.
Cheers
Dharmit
You have to use the portable version from the "Desktop Linux" build (unzip the tar and gzip packages, then simply copy the plugin in the "plugins" folder); here there is the 0.96.4875 version of this distribution with a large set of unofficial plugins.
best regards,
w3b5urf3r
#3 Опубликовано: 19.05.2013 18:15:00
Dharmit
Dharmit
Thanks w3b5urf3r,
I have downloaded SMath from the link in your post and it works.
The version I downloaded is just like Portable version as I didn't need to install it on my computer and as long as .net is there on target machine it will work.
Cheers
Dharmit
