Hardy Cross / Moment Distribution Method
Hardy Cross / Moment Distribution Method - Сообщения
#1 Опубликовано: 17.02.2021 06:27:00
hanskl
hanskl
7 сообщений из 158 понравились пользователям.
Has anyone performed the Hardy Cross / Moment Distribution Method on a continuous beam in SMath? Are there any examples of this on the forum?
Best regards,
#2 Опубликовано: 19.02.2021 16:25:07
Hans, no much audience for that one !
My only competence is monkey see monkey do.
... not finished yet that demo.
Cheers ... Jean.
Page1 Hardy-Cross.sm (50,97 КиБ) скачан 1323 раз(а).
#3 Опубликовано: 19.02.2021 21:41:04
hanskl
hanskl
Jean,
Thanks for having a look.
Its the part below that is the technically new/challenging part for me. I cant quite visualize the "framework" to set it up if you will.
Best regards,
#4 Опубликовано: 20.02.2021 02:09:55
Laurent Fournier
Laurent Fournier
9 сообщений из 66 понравились пользователям.
Hi, I do that not by computation but graphically on CAD by moving the "baseline" which is substracted from an assumed simply-supported moment at each span. For me the advantage is, it's very visual so errors are instantly visible, options are also visually obvious, so design decisions can be taken quickly. (I draw parabola in CAD as segments of very very elongated ellipses).
#5 Опубликовано: 20.02.2021 09:43:48
steps are the missing links ... out of the blue !
