Font size and symbols
Font size and symbols - Сообщения
#1 Опубликовано: 12.04.2011 11:19:58
Oscar Campo
Oscar Campo
134 сообщений из 309 понравились пользователям.
I use SMath for some classes in the university, by video beam. When I tried to change the font size for easy viewing for students I found that although I changed the font size, the symbols remainded at original "10 pts heigth". I created a simple file to show this issue:
Observe that as you increase the font size, the relative position of the subscripts, superscripts and operators, changes dramatically to the point that at a size of 50 pts is difficult to clearly identify them.
Oscar
#2 Опубликовано: 12.04.2011 12:48:32
Hello Oscar,
I hope you would not mind sugesting you not to increase font size when using SMath in your classes. A better way would be to use some zooming tool. Here is a free one (if you use Windows) - ZoomIt.
#3 Опубликовано: 12.04.2011 13:54:41
Oscar Campo
Oscar Campo
... A better way would be to use some zooming tool. Here is a free one (if you use Windows) - ZoomIt.
Thanks Radovan, I tried that solution, but it would be wonderful if the font size and symbols could be changed without changing the overall appearance
Oscar
