Nightly build: SMath Studio 0.96.5146 (02 February 2014)
Nightly build: SMath Studio 0.96.5146 (02 February 2014) - Сообщения
#1 Опубликовано: 02.02.2014 06:54:25
2 337 сообщений из 4 035 понравились пользователям.
Группа: Super Administrator
Nightly build: SMath Studio 0.96.5146 available
Important notes
  • Custom Regions plug-ins created for previous versions of SMath Studio will not work. Please contact developers of such plug-ins and ask them to update plug-ins. Sorry for the inconvenience!
    Показать спойлер
  • No official portable version will be available for this release.
Latest changes (against SMath Studio 0.96.4909)
  • Complexities in sys(), line() and matrix() resizing fixed;
  • Fixed issues of opening Dynamic Assistance list after collapsed Area(s);
  • Handling of broken plug-ins on application loading and on plug-ins installation improved;
  • Backspace handling improved when cursor is on the worksheet;
  • Inserting number before variable automatically sets multiplication operator between those number and variable;
  • Fixed unhandled exception on copy/paste of empty placeholder;
  • German units names added;
  • Added support for text entries and descriptions of not installed language;
  • [DEV] Added API to export worksheet per pages;
    Показать спойлер
  • [DEV] Correction to RegionHolder in order to allow changing size of the region by resizing of canvas (structure inside RegionHolder);
  • Code certificate updated;
  • Language files updated;
  • Refactoring and optimizations.
Download
7 пользователям понравился этот пост
Martin Kraska 02.02.2014 07:40:00, ioan92 02.02.2014 08:54:00, Radovan Omorjan 02.02.2014 09:07:00, Вячеслав Мезенцев 02.02.2014 09:27:00, IVR 03.02.2014 05:13:00, sergio 03.02.2014 13:58:00, Davide Carpi 02.02.2014 08:01:00
#2 Опубликовано: 02.02.2014 07:39:10
1 353 сообщений из 2 266 понравились пользователям.
Andrey, thanks for the update.
For testing I recommend to use the Linux version. As usual it can be used under Windowsm as portable version when an empty file "portable.version" is added to the installation directory. Then you can keep all extensions and settings separate from your standard installation.
An unofficial portable version will certainly be available, depending on upgrade progress of custom regions.
Unfortunately, the Maxima plugin is affected by API changes as well, even if not providing a custom region, access to the insert menu or custom windows seem to be problematic as well.
#3 Опубликовано: 02.02.2014 07:52:49
FYI: I've just added a spoiler about what to be done to update Custom Regions related plug-ins.
Davide Carpi 02.02.2014 08:01:00, Radovan Omorjan 02.02.2014 16:43:00
#4 Опубликовано: 02.02.2014 10:05:01
The following plug-ins updated to support SMath Studio 0.96.5146:
  • Combobox Region
  • Checkbox Region
  • Modeller Region
  • Export to PDF
Davide Carpi 02.02.2014 10:06:00, Radovan Omorjan 02.02.2014 16:43:00
#5 Опубликовано: 02.02.2014 10:45:02
  • Modeller Region
Any hint on how to use it? How about gallery example passwords?
Might be really interesting and powerfull stuff...
