Calculated values not displayed
Calculated values not displayed - Calculated values not displayed - Сообщения
#1 Опубликовано: 12.10.2018 09:29:38
Ramon Tavarez
Ramon Tavarez
2 сообщений из 12 понравились пользователям.
Hi.
After installation of v0.99.6839 the calculated values are not displayed.
I uninstalled and reinstalled Smath v 0.99.6839, and the problem persist.
I unsinstalled and reinstalled a previous version and the problem is still there
(when the previous version was installed and runnig there was no problem).
images of sample and computer info attached.
Thanks for the support.
#2 Опубликовано: 12.10.2018 09:35:45
Arie
Arie
Can you attach the .sm file in question?
#3 Опубликовано: 12.10.2018 09:49:13
Ramon Tavarez
Ramon Tavarez
Here the file.
Created with v 0.99.6858
issue example.sm (8,93 КиБ) скачан 1368 раз(а).
#4 Опубликовано: 12.10.2018 10:18:03
the problem is not confirmed with Win7 pro and SMath v0.99.6858.
#5 Опубликовано: 12.10.2018 10:28:39
Ramon Tavarez
Ramon Tavarez
The issue is confirmed on Win 7 Pro 32 bit since v 0.99.6671
#6 Опубликовано: 12.10.2018 11:43:31
Arie
Arie
Looks ok on my machine. Did you happen to turn off Auto Calculation? What happens if you press F9?
#7 Опубликовано: 12.10.2018 11:51:16
Ramon Tavarez
Ramon Tavarez
on F9 recalculates manually.
What I need is autocalculation. (I didn´t turn it off)
#8 Опубликовано: 12.10.2018 11:56:11
Arie
Arie
Correct, I was just trying to determine if you simply needed to calculate the page. The only way I could recreate what you showed is if I turned off auto calculation
If pressing F9 actually showed the values you can turn Auto calculation back on by going to menu bar clicking Calculation -> Auto Calculation.
I'm assuming auto calculation is off because in your screen shot, the last line is actually an assignment. If auto calculation were on, that incomplete assignment would be outlined in red.
#9 Опубликовано: 12.10.2018 11:57:14
It is currently enabled?
#10 Опубликовано: 12.10.2018 12:34:36
Ramon Tavarez
Ramon Tavarez
@Davide: Yes. It displayed as marked (activated option), but still wasn´t working.
@all:
I uninstalled all once again, then cleaned all registers on the system and then reinstalled Smath.
Now everything works as it should work.
(extrange behavior )
Thanks again for your support
Keep working this way.
