Radians to degrees?
Radians to degrees? - trigonometri - Сообщения
#1 Опубликовано: 06.12.2012 08:28:27
Kasperhaack
Kasperhaack
Im working with trigonometry, how do I get the cos and sin functions to return the result i degrees?
#2 Опубликовано: 06.12.2012 09:24:29
1 436 сообщений из 2 918 понравились пользователям.
Hi [userlink]Kasperhaack[/userlink]
To show or to customize an output unit you must type the apostrophe on the placeholder in the right side of the equation, and then you can type the unit ° or you can choose one from the list that appear (the dynamic assistance box).
EDIT: see also UNITS ON WIKI
regards,
w3b5urf3r
#3 Опубликовано: 06.12.2012 11:11:00
Oscar Campo
Oscar Campo
Kasperhaack,
In the same way you can use degrees inside trigonometric functions:
cos(45° )=0.7071
Oscar
#4 Опубликовано: 10.12.2012 06:58:30
Kasperhaack
Kasperhaack
Thank you guys!
#5 Опубликовано: 08.05.2013 06:29:38
120 сообщений из 337 понравились пользователям.
looks like they're back problems with degrees in 0.96.4875 version.
such as "cos (45°)" does not work in numeric mode
#6 Опубликовано: 08.05.2013 06:57:58
works for me (win7 x64)
#7 Опубликовано: 08.05.2013 07:11:47
from me no
win7 64
[albumimg]120[/albumimg]
#8 Опубликовано: 08.05.2013 08:05:51
It works for me as well
Win7 - 64
#9 Опубликовано: 08.05.2013 08:38:00
from me no
win7 64
Qual'è il messaggio di errore? Puoi postare questo file?
What's the error message? Can you share this file?
#10 Опубликовано: 08.05.2013 09:28:25
Oscar Campo
Oscar Campo
from me no
win7 64
Hi Sergio, what is the error message from SMath in the "cos(45° )= " in numeric mode?
Oscar
#11 Опубликовано: 08.05.2013 10:13:56
The PC reboots everything works correctly
I remember that the problem occurred after testing Radovan files with two files that interfere "No_units_used.sm" and "Units_dont_mathc.sm"
I think it's related to that problem but I did not understand in what way.
As written by Ioan there may be a problem internal memory management to Smath
Per Davide (se ciò che ho scritto sopra è gravemente scorretto per favore correggimi)
Al riavvio del PC tutto funziona correttamente.
Ricordo che il problema è avvenuto dopo aver testato i file di Radovan con i due files che interferiscono "No_units_used.sm" and "Units_dont_mathc.sm"
Credo che sia legato a quel problema ma non ho capito in quale maniera. Come scrive Ioan potrebbe esserci un problema di gestione della memoria interno a Smath
#12 Опубликовано: 08.05.2013 10:36:47
Ok, I understand; this permeability is not good . However remember that SMath Studio 0.96.4875 is a "nightly build" (a beta, in practice ) so could cause some issues....
Ok ho capito, queste interferenze tra files non mi sembrano una buona cosa. Comunque ricorda che l'ultima versione è una "nightly build" (una beta, fra l'altro è stata postata solo nella sezione inglese del forum e in una sotto-sezione a parte) quindi è facile che contenga errori.
best regards,
w3b5urf3r
sergio 08.05.2013 11:04:00
