Generating multiple plots using loop with series name (legend)
Generating multiple plots using loop with series name (legend) - Сообщения
#1 Опубликовано: 15.12.2024 20:21:27
usamakhan
usamakhan
6 сообщений из 93 понравились пользователям.
I am using XY plot to generate multiple graphs, however I am doing it manually. How can I
1] Script a loop to dynamically generate multiple plots
2] Dynamically generate series name (which will be used for plot legend)
NaOH_Demiwater_VECTOR.sm (23,47 КиБ) скачан 1711 раз(а).
#2 Опубликовано: 15.12.2024 23:26:07
If Maxima is an option for you, then you can entirely automate the production of plots.
For an overview on available plot objects and options see SMath with Maxima.
In X-Y Plot, you can use geometric objects to create the lines and perhaps also a legend.
BTW, there is no point of naming the variable Load.kAmp, because the value is converted to A anyways directly upon storage, unless you just store a number, bypassing the SMath unit system. When you retrieve numerical values, you decide what units to use, independently of what was originally used to specify the value.
NaOH_Demiwater_VECTOR_Kr.sm (208,46 КиБ) скачан 1775 раз(а).
usamakhan 16.12.2024 00:25:00
#3 Опубликовано: 15.12.2024 23:58:49
usamakhan
usamakhan
Unfortunately Maxima is not supported under Linux ..I am using MONO version
Also Image Region plugin is bugged under Linux
Extremely thanks for help anyway
