str2num problems with regional settings
str2num problems with regional settings - Сообщения
#1 Опубликовано: 03.10.2012 12:48:43
Hi
str2num has problems with nonstandard settings of decimal delimiter (komma) and function argument delimiter (semicolon). The error message indicates that the function tries to convert the internal argument separator (komma) to periods.
Best regards, Martin Kraska
Edit: Seems that the bug has been fixed:
[MATH lang=ENG]str2num(num2str(sys(1.2,2,2,1)))=sys(1.2,2,2,1)[/MATH]
str2num.sm (2,18 КиБ) скачан 1463 раз(а).
#2 Опубликовано: 12.10.2012 03:43:26
Another issue with regional settings.
When a variable name or a function name created using default settings (decimals->period,separator->comma) contains a semicolon (maybe in the subscript or not), opening the file with different settings (decimals->comma,separator->semicolon) cause an "empty stack" error (and the file can't be opened).
regards,
w3b5urf3r
semicolon_bug.sm (1,24 КиБ) скачан 1433 раз(а).
#3 Опубликовано: 27.05.2013 06:26:06
regards,
w3b5urf3r
No chances to fix this? It's critical when sharing worksheets based on norms like Eurocodes or similars...
best regards,
w3b5urf3r
ioan92 27.05.2013 17:01:00
#4 Опубликовано: 29.05.2013 15:11:38
Группа: Super Administrator
I see the only way to fix it is to forbid semicolon symbol in variables/functions names. I'll do it.
I think instead I need to implement some common way to allow any characters to be used in names. But a bit later...
Best regards, Andrey Ivashov.
ioan92 29.05.2013 15:53:00
#5 Опубликовано: 29.05.2013 16:37:49
One of the most missed characters is the % sign (as a unit name, '%:0,01), in order to avoid ugly constructs like in the attachment.
Andrey Ivashov 31.05.2013 00:48:00
#6 Опубликовано: 29.05.2013 16:58:48
mhhh... ok... I know, dot, comma and semicolon are special and sensible characters....
There are some unicode characters very similar ‚ ; I don't know if could be useful for the development of these exceptions (as dirty idea when an user is typing the name of the variable/function, Smath can convert "on the fly" the keyboard comma and semicolon input into this characters...)
thank you for any your effort
w3b5urf3r
