ODE RK Quick Trick
ODE RK Quick Trick - ODE RK Quick Trick - Сообщения
#1 Опубликовано: 27.10.2016 13:00:54
Hello Radovan and all,
Do you have a trick to manage that system ?
Thanks in advance, Jean
ODE rk Quick Trick.sm (9,15 КиБ) скачан 1271 раз(а).
#2 Опубликовано: 27.10.2016 14:46:11
Sorry Jean, I do not understand what did you mean by "trick".
Those are three linear first order ODE which are very often found in reaction kinetics. It seems to me that this would be no problem at all in numerical solving of them. Analytical solution should be also obtained by the appropriate method for such system.
Ra
#3 Опубликовано: 27.10.2016 22:48:01
Quite right Radovan about analytical methods.
Read more from former Mathsoft Collabs: Valery and Viktor,
link in the work sheet.
ODE Laplace Kinetic Reaction.sm (47,62 КиБ) скачан 1315 раз(а).
Radovan Omorjan 28.10.2016 06:28:00
