Booting metafiles from old MathCAD files
Booting metafiles from old MathCAD files - how boot metatfiles = pictures - Сообщения
#1 Опубликовано: 24.08.2015 14:11:18
Roger Schultz
Roger Schultz
Many of my MathCAD 13 files will not fully load as they contain pictures where the Smath loading complains trouble with “metafile”.
As a many year user of MathCAD I used that software to recursively calculate the same things about many different items. The mathematics being set up and correlated with a complex configuration documented by pictures included from other means typically a CAD rendered, labeled model obtained using screen capture.
Do translation means exist now or does this require new functionality in SMath?
#2 Опубликовано: 24.08.2015 19:16:40
Probably the translation should be improved. If you have examples this might help...
