Matrix inside a matrix
Matrix inside a matrix - Сообщения
#1 Опубликовано: 23.11.2021 14:33:01
PedS
PedS
Hi everyone
I am trying to create a matrix inside a matrix using a for loop.
This is what I did:
Matrix inside a matrix.sm (12,42 КиБ) скачан 1240 раз(а).
This works but my real data is much larger than the one in this example and it takes like 10 minutes to run. Is there a more efficient way to do this?
Thanks.
#2 Опубликовано: 23.11.2021 15:35:19
Your example runs in 0.5 s [Steam Engine Win 7]
Matrix inside a matrix.sm (12,63 КиБ) скачан 1270 раз(а).
#3 Опубликовано: 23.11.2021 17:51:39
Arie
Arie
Two things. One move the assignment of p[k to under the k for loop. You're reassigning to p too often. Also, for large datasets, it helps to initialize the size of the matrix rather than just increasing the size over each iteration. See attaached. Matrix inside a matrix_lyles.sm (15,1 КиБ) скачан 1246 раз(а).
sergio 24.11.2021 06:03:00
#4 Опубликовано: 23.11.2021 18:06:24
Hola Pedro. Please check this version and tell us how long it takes with your data.
Matrix inside a matrix.sm (31,03 КиБ) скачан 1251 раз(а).
#5 Опубликовано: 23.11.2021 18:54:21
Two things.
On my Win 7 ... takes 4 times my original SS 6179 doctored version.
Has it dependence with Smath version ?
Cheers ... Jean.
#6 Опубликовано: 23.11.2021 19:00:08
Timing is about twice my doctored version.
#7 Опубликовано: 23.11.2021 19:20:04
PedS
PedS
Thanks a lot, this works perfectly
#8 Опубликовано: 23.11.2021 19:21:22
PedS
PedS
Gracias, aprecio tu ayuda
#9 Опубликовано: 23.11.2021 21:51:43
... annotated attachment ...Cheers ... Jean
Matrix inside a matrix (Proposal).sm (31,59 КиБ) скачан 1219 раз(а).
#10 Опубликовано: 25.11.2021 09:15:52
1. Wait and see your next Monster Big.
2. 10 min on your machine might take 1 hr on mine, but willing.
3. Maybe not not so big and interpolate ?
See you sometimes, Cheers ... Jean
