change variable name
change variable name - Сообщения
#1 Опубликовано: 09.02.2023 06:31:07
susilo widyatmoko
susilo widyatmoko
5 сообщений из 9 понравились пользователям.
I know there is a way to change variable name at once, but it is must be on one line program. is there any option to change variable name? just like when you rename variable in matlab.
#2 Опубликовано: 09.02.2023 08:33:14
Install Text Region Utilities plugin.
There is a Search and Replace feature in it.
You can change a variable name across all sheet.
Or you can edit file with a text editor (notepad).
sergio 09.02.2023 09:28:00, Davide Carpi 26.06.2023 05:55:00
#3 Опубликовано: 09.02.2023 12:27:16
I know there is a way to change variable name at once, but it must be on one line program
... multiline program as well from F8 key.
#4 Опубликовано: 26.06.2023 01:08:36
netsonicyxf
netsonicyxf
2 сообщений из 79 понравились пользователям.
Could you plz show me how to do it?
