Piecewise fuction - type conversion error
Piecewise fuction - type conversion error - Piecewise fuction - type conversion error - Сообщения
#1 Опубликовано: 18.01.2019 22:16:30
justhumm
justhumm
0 сообщений из 18 понравились пользователям.
I was playing around with SMath and trying to graph a piecewise function curve. I am receiving a "Type conversion error. Please contact the developer." message.
Any ideas what is causing that? version 0.99 (build 6884)
piecewise.sm (30,45 КиБ) скачан 1384 раз(а).
#2 Опубликовано: 19.01.2019 05:24:23
the problem is that in boolean comparisions you are using matrices instead of scalars (in both arguments, x and um)
#3 Опубликовано: 19.01.2019 09:11:33
For plotting, if/otherwise is convenient. Generally, for maths: if/else.
[< ...>] are for while loops and some exceptional algorithm(s).
Observe the undocumented min(x).
For Derivation/Integration of discontinuous functions use FD [Finite Differences].
Integrate Discontinuous [min(x)].sm (14,25 КиБ) скачан 1206 раз(а).
Integrate Discontinuous [Nuance].sm (24,75 КиБ) скачан 1190 раз(а).
#4 Опубликовано: 19.01.2019 14:10:03
justhumm
justhumm
Thanks for the replies!
