using defined constants as variables
using defined constants as variables - Сообщения
#1 Опубликовано: 28.10.2016 00:09:52
studoc
studoc
0 сообщений из 17 понравились пользователям.
Can I use "e" as a variable…?
#2 Опубликовано: 28.10.2016 04:20:33
Hello [userlink]studoc[/userlink]
Yes, you can use e as variable
#3 Опубликовано: 28.10.2016 11:58:14
Generally you can use 'e' as a variable. It did create disaster in
many Mathcad applications. Always sanity check your results.
Bad practice: e^1.23456789
Good practice: exp(1.23456789)
