Create a new variable for each row of a system of values
Create a new variable for each row of a system of values - How to automatically create a new variable for each matrix inside a system (or other matix) - Сообщения
#1 Опубликовано: 04.12.2014 18:43:40
Ryan Freund
Ryan Freund
20 сообщений из 339 понравились пользователям.
Is it possible 'automatically' create a new variable for each row of a system?
Basically you have a matrix (baby matrix) inside a larger matrix (mother matrix). how do I access the values inside the baby matrix. I'm sure there are better math terms to use here... sorry.
Say for example you have a certain number of wall lines in a building and along that wall line there different lengths of wall between openings. Now you have a row matrix for all the lengths of wall in that wall line. That matrix is in a larger matrix which contains all the walls at that floor level which may be inside of a matrix which has all the floors.
But in any case can I automatically create variables which will be equal to the baby matrix?
This may be confusing, I will try to work on an example.
Thanks!
#2 Опубликовано: 05.12.2014 03:22:16
brotjob
brotjob
7 сообщений из 71 понравились пользователям.
...you have a matrix (baby matrix) inside a larger matrix (mother matrix). how do I access the values inside the baby matrix.
see attachment screenshot
#3 Опубликовано: 05.12.2014 09:22:54
Ryan Freund
Ryan Freund
Thanks!
I suppose I could have said 'child', 'baby' sounds a bit odd...
