Beta: SMath Studio 0.99.6858 (11 October 2018)
Beta: SMath Studio 0.99.6858 (11 October 2018) - Сообщения
#1 Опубликовано: 10.10.2018 19:54:46
Группа: Super Administrator
Скачать
SMathStudioDesktop.0_99_6858.Mono.tar.gz (1,34 МиБ) скачан 2730 раз(а).
SMathStudioDesktop.0_99_6858.Setup.msi (2,21 МиБ) скачан 5699 раз(а).
9 пользователям понравился этот пост
Вячеслав Мезенцев 11.10.2018 04:24:00, Davide Carpi 11.10.2018 04:25:00, frapuano 11.10.2018 05:10:00, NDTM Amarasekera 11.10.2018 05:10:00, sergio 11.10.2018 05:15:00, Arie 11.10.2018 08:35:00, overlord 12.10.2018 12:46:00, Denis Nikitin 16.10.2018 02:24:00, Serg 18.10.2018 03:10:00
#2 Опубликовано: 12.10.2018 13:38:12
601 сообщений из 1 382 понравились пользователям.
New header-footer option is awesome. This will help me to reduce file sizes a lot.
By the way I noticed the linux and windows versions have layout difference.
Same file opened in SMath (6853) via "Arch Linux" an "Windows 10" has misaligned regions.
Regions under Linux are wider and pictures regions are bigger I guess.
I use cups-pdf to preview under Linux if it will help and I just noticed I can't print to pdf. But I can preview it.
Regards.
#3 Опубликовано: 14.10.2018 06:28:42
ianlh
ianlh
0 сообщений из 38 понравились пользователям.
On this latest version (mono), when selecting the units, the box only fills with the first. when required to use a different unit you can move down, but nothing is shown apart from the help/hint box.The Linux version i am using is Mint 18.3.
#4 Опубликовано: 15.10.2018 16:01:30
There is no "Field" entry in the Text_Eng.lang file (for Insert> Field).
#5 Опубликовано: 17.10.2018 14:42:38
Alexander O. Melnik
Alexander O. Melnik
Thank you for great formatting updates!
May I place a request please? It is often useful to record a date calculation page was created on. Is it possible to have a date field that is updated only when it is created or copy pasted instead of being continiously updated when file is opened or reloaded?
Thanks!
#6 Опубликовано: 17.10.2018 18:14:08
Arie
Arie
Thanks!
In the meantime, You could manually achieve this by right-clicking date field and choosing "disable evaluation" after the file is created the first time. Re-enable, reevaluate sheet, then disable anytime you recopy file or want to update the field. .
sergio 18.10.2018 04:55:00
#7 Опубликовано: 18.10.2018 18:00:08
May I place a request please? It is often useful to record a date calculation page was created on. Is it possible to have a date field that is updated only when it is created or copy pasted instead of being continuously updated when file is opened or reloaded?
Interesting request, but between the moment a work sheet is first created
and the last saving [dozen and dozen times saved], the first time saved
has no more meaning: is it ?
Windows timestamp [hover on sheet name] is the last saved.
Print preview page header is the actual time
#8 Опубликовано: 19.10.2018 12:46:24
Farja
Farja
1 сообщений из 7 понравились пользователям.
I know the limitations for importing Mathcad files. I have used it in the last couple of months without much trouble to partially import old mathcad sheets.
But, i get this error with the latest version: "Object reference not set to an instance of an object."
Thanks!
#9 Опубликовано: 21.10.2018 09:06:25
Kizilcay
Kizilcay
I observed the same error with the same Smath Studio version on Windows 8.1 (German). The message appears in German:
"Der Objektverweis wurde nicht auf eine Objektinstanz festgelegt".
Should I try to reinstall version 0.99.6839 - Stable (released at 2018-09-22) - recommended?
Thanks for the help in advance.
Mustafa
#10 Опубликовано: 21.10.2018 09:15:00
Kizilcay
Kizilcay
Just an update to the above error message. I uninstalled the latest beta version and installed the last stable version 0.99.6839. The problem was solved. I can open/import Mathcad files (.xmcd).
#11 Опубликовано: 26.10.2018 14:55:58
Thanks!
Thank you for the report. Issue is fixed now. Fix will be available into the next beta release.
Best regards!
