Rail Gun ODE
Rail Gun ODE - File Conversion from MC Prime - Сообщения
#1 Опубликовано: 04.04.2023 22:31:27
Norm Schutzkus
Norm Schutzkus
9 сообщений из 90 понравились пользователям.
Hello SMATH Collaboratory,
I attempt to convert a Prime sheet to SMATH. The Prime sheet uses a solve block with "Odesolve" (pdf attached). I tried using "ODE2" but I do not have Maxima installed.
Is there another route?
I welcome your review and look forward to your replies.
Sincerely,
Norm
#2 Опубликовано: 05.04.2023 00:38:46
Hi. You can try this. Even this returns functions for I(t), Vr(t) ... there is a unit issue. But you can use the values in rk with cinterp for reconstruct the functions with units.
Rail Gun ODE.sm (22,74 КиБ) скачан 1221 раз(а).
#3 Опубликовано: 05.04.2023 10:03:29
Norm Schutzkus
Norm Schutzkus
Hello Alvaro,
Awesome! Thank you, for your help!
Sincerely,
Norm
