1 страниц (5 вхождений)
Eigenvalues and eigenvectors - Сообщения
Is there a built in function for extracting eigenvalues and eigenvectors from matrices?
Thanks
Thanks
Hi. Try this plugin
https://en.smath.com/forum/yaf_postst1918_DotNumerics.aspx
There you have dn_LinAlgEigenvalues and other for Eigenvectors
This is my attempt for do eigenvectors without plugins. Sometimes give better values than dot numerics, and other times fails, because I haven't a simple code for do the pseudo inverse for this code, and use SMath's inverse() which have some bugs.
MEigen with rref.sm (103,07 КиБ) скачан 1277 раз(а).
MEigen with rref.pdf (296,14 КиБ) скачан 881 раз(а).
sergio 04.12.2020 06:21:00
WroteIs there a built in function for extracting eigenvalues and eigenvectors from matrices?
Visit this Companion ...
Maths eigenAll Companion.sm (66,98 КиБ) скачан 1376 раз(а).
Thanks everybody.
