ODE Solvers Tests
ODE Solvers Tests - Сообщения
#1 Опубликовано: 07.12.2021 17:10:30
Test your ODEsolve.
ODEsove Test.sm (9,51 КиБ) скачан 1549 раз(а).
#2 Опубликовано: 07.12.2021 17:28:56
Test your ODEsolve.
Jean, you can do it yourself. There are no changes in the numerical solvers yet. Therefore, it makes no sense to repeat the same thing. The block I added doesn't do any calculations. All old numerical methods are used. There are no new numerical solvers.
If you really want to help test the solvers, then translate these 295 examples from Mathcad to SMath Studio:
295 Mathcad Worksheets for Ordinary Differential Equations (Schittkowski).pdf (542,46 КиБ) скачан 1659 раз(а).
Links:
1. 295 Mathcad Worksheets for Ordinary Differential Equations
2. mc_ode.zip ( about 7.3 MB )
3. Numerical Data Fitting in Dynamical Systems: A Practical Introduction with Applications and Software (Schittkowski, 2002) (z-lib.org)
